Transom saver.....???????
staydry
Last weekend noticed that the aluminum pan that the motor attaches to had stripped a bolt...looked like a few more bumps and the engine may fall off.....returned to dealer (its only 3 yrs old) to take a look at. They talked with factory rep today...the factory guy will pay for all repairs on it but I must start using a transom saver for now on because if it happens again...they won't fix it.
My motor is a 90 the boat is rated for a 115...I've never seen a transom saver on a pontoon before...not sure how you could even get one to work...:confused:
Jeep Man
Re: Transom saver.....???????
Why not ask the dealer how it would attach effectively. That way, your butt is covered.
ddrieck
They do make an transom saver that in quite long that comes out and then angles up to support the outboard. I have seen them on the Shore lander trailers but do not know where to get them.
Water logged
Tracker recommended the use of a transom saver on my boat. They installed a hookup on the trailer, but did not include the saver:confused:
Glenn
Mr Crabbs
The "Motor Toter" came with my new trailer. It's a simple support bar and takes less than a minute to install. If I get a chance, I'll take a pic.
gerg
commander315
I agree...ask the dealer/manufacturer how to install and which transom saver to use... this way they can't say it was your fault is something goes wrong again.
Mr Crabbs
This is what I used on a previous pontoon. http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_83274____SearchResults
One end attaches(with quick release pin) to the middle of the rear trailer frame, the other end cradles the lower unit when it is in partialy raised position. This transfers some of the motor weight stress from the transom to the trailer frame when trailering the boat.
That's the one that came with my Suntracker. Works great.
dodger11
Mine is just 2 quick self tap screws to the trailer for the bracket, 2 turns in with the transom saver rod and trim down till you get a snug fit on the motor, throw a bungee around it & off you go.
staydry
Took a whole month but finally got the boat back...factory evidently decided to beef up the replacement pan and transom saver does fit....
EricJRW
That's pretty cool. Looking at the damage photos, and the transom saver, I can see how that would stop the rocking motion of the motor while it's on the trailer. If I ever have to trailer my pontoon (I don't even own a trailer), I'll have to keep that in mind.
Thanks for sharing.
samo_ott
That bar is at such an angle it's not taking much weight off the transom. It would save on some twisting and vibration though.
glengold
I agree the ones i've seen hold the motor at a much higher trim angle, supporting more weight. The entire thing look a TON more beefy, great warranty coverage!!!:cool:
JCH57
HI, I bought my toon in 06 from a rv/truck/car dealer. After we checked it out etc. , i was advised to get a transom saver. I frist got one that one end connected to the trailer, and the bar connected to it with a pin. It didn't hold the motor up very high, and i broke blade on the prop backing up in a parking lot, where it went down into a dip.
I replaced it with this one. It's adjusted all the way out, one end is round which fits over a tube on the rear frame of the trailer, and of course the other end connectes to the lower end of the motor. It holds the motor up a good distance from the ground. I put an ibolt on the stem, with a bungie cord to hold it on as a safety precaution, so when i releive some pressure on the trim motor, it stays on the frame. Bought it on ebay for $19.95 plus shipping. :D
lamac
My transom saver is extended out further and my motor is about a 45 degree angle to support the weight more. Mine came with the boat and this is how the dealer had it adjusted.
mla2ofus
Is it possible to move your winchpost ahead a few inches so you can get a higher angle of the motor w/ the transom saver?
Mike
Water logged
Mike
It doesn't look like he has the saver extended to full length. that would allow raising the motor higher
Glenn
ozarkglen
I bought my transom saver at good ole Wal-Mart for under $20. Looks the same as the last pictures and can lenthed to fit your trailer needs. The one point I would add is that the boat must be tied down to the trailer to prevent bouncing while towing.
