Re: why is brake petal hard?
Start your car let it run for a minute or so. Shut the engine off. Press the brake pedal several times until it becomes hard (you're bleeding off the vacuum in the brake booster at this point), it may take 6-8 pumps on the brakes. Once it's hard, keep your foot on the brake pedal and start the engine. You should feel the brake pedal drop as you start it. If you don't feel it drop you either have a bad brake booster as everyone has mentioned, or you have a vacuum leak to the brake booster.
Before replacing the booster, check to see if you have hole in the vacuum hose going to the booster. Make sure the line has not come loose. But, more than likely with the noise coming from the brake pedal area when you apply the brakes you are going to need a booster assembly.
Oh yeah, check to see if you have paint bubbling on the bottom side of the booster where the master cylinder mounts to it. If so, you will either need to rebuild your master cylinder or get a new one. If your master cylinder is leaking into your booster it can cause premature failure of the vacuum diaphram.
Let us know.
