Hi, I have 1979 Privateer C/C and am replacing the fuel tank. After replacing the tank (under the console and decking) I have a couple questions on the type of wood I should use and am having trouble finding the clear answer beings it seems this is always a big debate.
Decking... Standard exterior plywood or marine? I will be putting resign on the entire patch and glassing the seams then painting over the entire deck after the project is complete.
Ribs over the tank (between the stringers)? Treated or standard and Should I coat these in resign or glass also?
Screws to hold it all together, Are deckmates sufficient? or should I order some type of stainless wood screw?
I am planning on keeping the boat at least another 5 yrs.
Any other tips on aluminum tank replacement would be apprieciated... Lee
