lakelover
- Mar 26, 2003
- 4,390
This is pretty model specific...
I changed the impeller and am having a lot of trouble in reassembling, getting the washer on top of the shift shaft before it passes through the reverse rod hook.
I did this 3 years ago and it must have been dumb luck, because I got it back together pretty quickly by using a flat piece of plastic and marine grease to stick the washer on top of the shaft as the lower unit is lifted back into place. There's practically zero working space.
Is there a better way?
