Re: 20 horse Chrysler outboard leaking gas through exhaust
Have you run the motor with the engine?s cover/cowling off to check for leaks? Otherwise, you might have a rich running engine or un-burned gas due to ignition problems that is making a mess. I have found both over the years with my 1970, 35 HP Chrysler. Such as:
1. I have found my fuel pump?s bowl loose and leaking.
2. In the cool weather a richer mixture seems to leave a exhaust/fuel/oil film on the water or in the barrel. I feel the film is less when the motor and weather is hot because it runs better in the heat.
JOW
