So I blew my lower unit and started taking it apart to see what happened. I removed the prop bearing housing, and the drive shaft came out just by pulling...well most of it anyway. Seems the lower drive shaft broke right at the pinion bearing. I can get a wrench on the pinion nut but of course the broken shaft just spins and it's too far down to get a hold of it. Any tricks to breaking this nut loose? Should I stuff a rag in the gears and just keep turning? I think this is the only damage so it's a much cheaper fix than a new lu, I just can't get it out....any help or old-school tricks will be very much appreciated!!
