Having some trouble with this one. Turn the ignition switch Starter doesn't kick in doesn't even try jump across the solenoid starter kicks in then I can use the key to start it. Changed the solenoid still does it. Talked to repair shop they said it could be the switch. So I changed that. Still the same. Good connections on the battery. Could it be the starter itself? Like I said it kicks in every time I jump across the solenoid. Then I can use the key after I jump it once. Any help would be appreciated. Thanks. JD
