Best anchor for my boat
kenny26
I just bit the bullet and bought a brand new Tahoe 195 deck boat.
I'm looking for a anchor for it. Something economical that will work well. The boat is 20' and close to 3000lbs. I'm boating in wisconsin lakes (mud bottom, weeds, 0 - 50 ft of water mostly). Looks like the anchor locker is sized for a fluke style.
What anchor? size rode? amount of chain?
Also, what backup anchor to control the stern from swinging? Small mushroom?
commander315
Re: Best anchor for my boat
Idk if your need a fluke anchor. (They skate in mud bottoms and are also horrible in heavy weed cover.). Go for a plow or bruce style anchor. Lead it with 2 feet of chain and then rope from there on. A medium mushroom should work for the back, or even a collapsible claw anchor.
robert graham
I has to depend on boat size, water depth, currents, tides, wind, weather, etc. If you're mostly in a lake with a soft bottom, without much wind or currents, then a 20lb. mushroom would probably work, most of the time. That's what I use and it's good, most of the time. If I'm going into the ocean or fast moving river then I'll use a different anchor, so it all depends on your boating/water conditions. You may need a couple of different anchors. Good Luck!
Kenny, Fluke anchors are superior to mushroom anchors, for temporary (non-mooring) anchoring. An 8 or 9# fluke anchor, 5 or 6 foot of chain and a couple of shackles to attach the anchor to the chain and the chain to the anchor line is the best idea. 3/8" twisted nylon line of 200' or so, should cover most of your shallow-medium deep water anchoring needs.
A stern anchor could be anything, however, a small fluke anchor is still the best.
JimKW
My anchor does not hold well and I was going to get some chain, but nowhere do I see what size chain to use. I almost got 3' of 3/8" chain, but that is some big stuff. So decided to check on here before getting anything.
Right now I just have about 100' of rode with a small flute type anchor. It says Hooker E10 on it and that's all it says. Looks like a really cheap anchor.
Stachi
my previous boat , came with a Danforth anchor with three foot of doubled 3/8" chain , twisted and also had three lead weights from a diving belt bolted through the chain to keep it twisted.... this anchor and chain set-up never failed in a tidal river .. Delaware River....
Boatist
Best anchor is a Fortress 4 pound anchor for boats to 27 feet. Digs in faster without dragging on the bottom. I have this anchor and a 8 pound Danforth but the Fortress digs in faster and holds better the the Danforth that is twice as heavy.
Even with no chain it diggs in faster with out dragging. The Danforth works ok also but is so heavy the wife has trouble pulling it up. Also in one lake where the bottom is hard it sometimes drags a lot before it digs in. This means it can drag until it hits a rock or log. When caught on a rock or log very hard to pull.
Check out the anchor test on the Fortress site. It is high priced but well worth it to us.
http://www.fortressanchors.com/
http://www.iboats.com/Fortress-Anchors/dm/*******.089918619--**********.549149598--view_id.4943
buckhorn237
I have a richter anchor it holds in so many different conditions I can't list
JimKW
Think I'll just get a different anchor. I really don't like the idea of pulling five or six feet of chain into my boat. Don't have time to order one, so I think I'll just see what West Marine has in the store.
JimKW
Well here's what I did: I went to West Marine and looked at what they had and what he wanted to sell me was pretty much what I have only smaller. They had the 4 lb Fortress, but for all the more often I anchor I could not see paying $132. What I have is a 10 lb Hooker, so I bought 4' of vinyl coated 1/4" chain and some of those things you use to fasten it to the rode and to the anchor.
Then I came home and went out all by myself, went back in a cove, sat there and unhooked the rode from the anchor, put the chain in between the anchor and rope, then threw it into the lake. Put the boat in reverse and let out rope until it grabbed, and it grabbed pretty quick and held good. Pretty sure that's all I'll need. Then when I was pulling it in, sure enough I touched the boat a little with the chain. Glad I went the extra $20 for the vinyl coating.
redone4x4
I have a 20# navy anchor and i love it. plus the shank slides up and down when not in use so its easy to store. a little heavy, yes but it works great. dont ask the wife to retrieve it though :D
