I am going to be restoring a 1979 Ranger 178V for my father.
I have not found may articles on refurbing a bass boat so I am looking for some advice.
1. My big debate is wether or not to remove the deck from the hull and just how involved that may get. I think that is the correct way to inspect everything and repair as needed. Front and rear live wells do not function properly, so I would like to be able to inspect the plumbing on them.
2. Steering rack is bent and needs replaced.
3. The paint is in very bad shape as it was left outside un covered and has bad sun damage. I am researching how much this restore will cost prior to starting the project. There are some repairs needed to the hull and deck such as small holes that I would like to patch and sand out. There is also a small 2"-3" crack in the transom on the deck side.
4. Trolling motor wiring needs some attention as well.
Looking for information on where to find any and all parts necessary.
-rubber molding at deck/hull
-deck paint... prefer red with flake to match existing color.
-hull paint... basic beige
-trolling motor wiring setup? such as the panel the trolling motor plugs into.
I will post some pics later tonight.
