i have a '93 70 horse that is now in the shop of the 3rd time in a month.  History - the engine sat up for about 18 months due to illness.  Fuel had been sabalized with Sea Faom before storage but nothing else done.  I pulled it home from stoarage - charged he battery - sprayed wd -40 into each cylinder and then hand turned the engine over and let it sit overnight.  Started right up the next day on muffs.  took it to the mech to tune up and tank test to make sure the high speed jets were clear.  Got it back and it ran well on muffs with a good tale tale.
Took it to the lake and ran it at 3/4 throttle for 10 minuted max and overheat alarm went off and tell tale started throwing steam not water. Over heat alarm never went off but tell tale picked up intermittently. Limped back to launch and took boat back to mech. He was able to duplicate problem in the tank after a bunch of running. Compression was within 10 % across all 3 clyinders. He replaced impeller and housing, thermostat and added scopes to the water pick up and tank tested. He also repalced heat alarm as it tested defective. He also changed the tell tale tap to the top of the head per envinrude service bulletin from 1994. All ran well.
Chapter 2 - picked up boat and took to water. Launched and within 10 minutes at 3/4 throttle heat alarm back on and steam coming from tell tale. Went to idle back to launch and tell tale picked up and alarm went off. Was afraid to rum it but came back to launch with tell tale working at 3/4 throttle say 4000 rpms. took it back to shop and the mech is baffled as to what to look at next.
Any advice?
Thanks
Any advice?
Thanks
