150 GT and 150 Fast Strike compatible?
ab1
As some of you know, I blew my lower unit and the teardown revealed that the housing is toast. Found a good used one but need to know if it will bolt up without mods.
Will a 94 Johnson 150 GT lower unit fit on a 93 Johnson 150 Fast Strike GLETR. I don't know the model of the GT unfortunately but he says it's 20" shaft so I'm half way there.
Looking at the 93 and 94 sales brochures, I don't show a GT...only the fast strike, so this guy might just have the name wrong.
Thanks for all your help so far...any input here is appreciated before I go pay for this thing.
ab1
Re: 150 GT and 150 Fast Strike compatible?
I'm still looking and can't find a 150 GT in 1994...only the fastrike so I'm guessing it will work.
I'm leaving in about an hour...if anyone can help I would REALLY appreciate it.
Melvin Hatcher
Get the model and serial number off the 1994 so called (GT 150) to be sure what you are buying. I think 1990-91 was the last GT - XP crossflow engines. At anyrate, you need to know what he selling and if you are willing to buy.
Good luck.
ab1
Thanks...Unfortunately, I can't get the numbers until I arrive. He's positive it's a 94 and a 150, but the GT is throwing me off. I don't think it's possible to have a GT in 94.
If I can confirm that all 94 150 (v6) lower unit would fit my 93 150 fast strike, then I'm good. Per the post above, I don't think they made anything else after 91.
It comes down to the shaft, 1 piece vs 2. I need the two piece but that's tough to tell unless you take it apart, which I cannot do on site.
Melvin Hatcher
Hope this help to identify the motor as a 1994 whatever.
http://www.theoutboardwizard.com/evinrude_model_number.html
ab1
Thanks...printed for reference.
If anyone else can add $.02, please do. I'll have the wife checking this post while I'm on the road.
Thanks again for all of your help!!!!! Hopefully I'll be back on the water in just a few days. My little boy keeps asking why I broke my boat. Good question, kid.
Melvin Hatcher
You are more than welcome, keep in touch and let us know how you make out.
Best regards.
Dhadley
A 150 Fast Strike is a 60 degree V6 looper, a 150 GT is a V6 crossflow. The gearcases will interchange but you'll have to make sure the driveshaft height is correct for the motor it's going on.
ab1
Did they make a crossflow in 94?
Dhadley
Yes, there was a crossflow in 94 but it was a V4. All 150 Fast Strikes are 60 degree V6 loopers. The 94 150s were 60 degree loopers.
ab1
^^^ Thanks! That's exactly what I needed to know.
