damaged bravo 3 props
jig head
my props have hit somthing, they both have 1 damaged fin. the damage is about a quarter inch peeled off, or a little less.
there is no vibration. should I be concerned with having any lower unit damage?
HT32BSX115
Re: damaged bravo 3 props
Howdy,
Possibly not...... you should still check the prop shaft(s) for run-out when you pull the props to repair/replace them.....
Regards,
Rick
KJSmitty
Depending on your boat insurance, they may cover you - and they normally want a prop shaft run-out check.
I would definitely want to know.
I'm not sure of the Bravo 3 reqs yet typically you should have .003 or less run-out on either shaft.
