Strange electrical issue w/ 88 40hp mariner
shawpdx1
When I plug in controls and turn key starter does not work and wiring heats up, but does not blow fuse
something must be grounded?? model # 40 O EL serial # 420625 anyone been through this?
I also have a OD 215849 25hp American made Mariner , I need a scamtic on Ignition wiring seems to be missing parts bought these at a estate sale for cheap seems to me this one would not have much ignition parts its pull start only and tiller operated
any help would be great
j_martin
Re: Strange electrical issue w/ 88 40hp mariner
Which wire. Follow the smoke to the wire on the wrong screw, along with a ground.
shawpdx1
No smoke just gets hot and does not blow fuse strange deal. If I bypass that saftey "N" switch and hook up cable to battery it turns over automatically
j_martin
Let me draw you a picture. Follow the hot wire to the fault.
shawpdx1
RIGHT ON !! that was a great answer! ..........I like it!! going to do that today
I was actually looking for a picture Thanks
shawpdx1
it seems to be the hot wires (red) I know that
Faztbullet
Is it the original control box or has someone splined it to engine? The Yammmerc's are wired different..
j_martin
Further diagraming (with a bit of crust)
HOT to the touch.:D
Actually, if you follow the wire emitting thermal energy to it's connection point, and took a picture, I bet somebody could key off that and help.
