Re: Seafoam Deep Creep?
I would use the regular Seafoam liquid.  The Deep Creep is more a penetrant liken to WD-40.  For a de-carb, use the liquid and save the DC for your rusted bolts and such.
Taken from their website....
"Deep Creep?s fast acting, 100% petroleum formula quickly penetrates rusted parts, lubricates moving metal parts, disperses moisture, and cuts through grease, engine varnish and road tar.  It withstands heat better than other penetrating oils ? allowing you to use it in combination with a torch to loosen a badly rusted part.  Deep Creep has hundreds of household and workshop uses and outperforms all the leading penetrating sprays on the market. Deep Creep?s unique spray can even works with the can held upside down so you can use it in difficult-to-reach applications."
Just my 2cents
Will
