Drive Shaft Shimming!?!? - Johnson 90
Palssonater
'01 Johnson 90HP V4. Turns out my cracked gearcase was severely distorted. Needed to order a new case all together. Putting everything back together now and wondering what dictates how much to shim the driveshaft. Shaft is spinning freely to prop but you can still hear the clicking of the gear. Is there a gear lash level that I should have at the prop. Running about 20 to 25 degrees now.
Any specs or procedures out of any manual would be very helpful. As well as any words of wisdom when dealing with shimming your driveshaft and reassembly of bottom end?
Palssonater
Re: Drive Shaft Shimming!?!? - Johnson 90
Is there anyone out there that can help me out. Can't even buy a Service Manual for this motor. J90PLSIF. There is an E90PLSIF(Evinrude) that oughta be close to it eh?
I really only need the driveshaft shimming procedure. Any Marine techs that have access to that info on here?
wilde1j
The OEM shop manual has the procedure ... the motors are the same except the color and logo. It's the prop shaft that needs shimming.
bob johnson
well there are DEFINATELY shims on the drive shaft!!!!!!! mine has three!!!
under the bearing housing which is under the water pump!!
i didnt see any shims on the prop shaft, but the book says there are shims used on the COUNTER rotation lower units!!!!
but they dont show any on the standard units!.....
bob
Palssonater
I haven't seen a shim on my prop shaft. Only on my driveshaft. Came out of the old "smushed" housing with .009. I did manage to find some specs from an marine tech. Looking for .020 of gearlash on the driveshaft between both gears. Guess I will go from there.
bob johnson
I can take pictures of the pages in my manual that deal with setting the drive shaft up....I bet they are close...the lower units interchange up to 2005 from what i hear( the eagle motor small gear case V4s)
if you need them...
bob
clanton
The measurement is between the pinion gear and drive shaft bearing housing plus .020. Pinon gear installed and torqued. Special or home made tool used to do this.
clanton
Poster Schematic may have the measurement.
Palssonater
bob johnson...that'd be awesome! Its exactly what I need. 0.020 is the spec I've gotten off a few people, but could sure use the procedure & location to measure it.
I am confused as to what you meant Clanton. The pinon gear and the driveshaft housing are seperated quite a ways away. Seperated by the lower driveshaft.
clanton
I will try to find a photo of shimming tool.
bob johnson
or this one
bob
Palssonater
Aha! It appears I had my theory wrong. The shim is not to really compensate for casting discrepancies of the lower unit, but more so for the joining of the pinion gear to the lower driveshaft(which is also cast), to the upper drive shaft. Got it now. I thought it was a measurement done after the driveshaft was placed in the lower unit.
Essentially 0.009 out, then 0.009 in when using the same drive shaft.
bob johnson
well...maybe not.....if you use all the same parts that came out...then yes...but if you buy a new driveshaft bearing housing..
then you will have to come up with new numbers...thus you need the tool....
PS: the tool has nothing to do with the upper drive shaft...just for shimming the lower driveshaft so that the pinion gear has the proper clearance....the pinion gears just goes onto the lower drive shaft all by itself...no shims under it or near it... the shims are all up by the drive shaft bearing and thrust washer!!!!!!!!!
at least thats the way i am seeing it..
bob
bob
jtexas
bob's got it right. The shims hold the pinion gear to the drive gears with proper amount of force -- too little or too much, the result is broken teeth.
The pinion gear has to be installed on the driveshaft and torqued to spec outside the motor for this measurement. And that distance is not published at least not in the manual for my motor.
