Hey Guys,
I know theres a set of questions you need answering but this is where I am stuck...
I purchased a four winns freedom 18" with an OMC 4.3 2 barrel carb 1990's ISH engine in it (175hp???) . It had a knackered leg on it so I set about a conversion to a merc alpha one leg with the SEI conversion. This has worked VERY well however. I didnt have enough to buy the kit and a new merc leg so a friend has given me a merc leg which has very little use.
According to SEI I required the 1.81 gear ratio to be rougly where the old omc leg was geared too however the leg I now have on the boat is a 2.00 gear ratio. The old OMC prop doesnt fit the merc leg so I havent been able to run the boat to get any kind of bench mark. I am looking for good hole shot as the boat will be mainly used to wakeboarding.
Any form of help would be great. i am sorry I cant provide a boat weight or anything like that.
Cheers matt
Cheers matt
