clancy1010
- May 31, 2009
- 11
I have bought a 75 650 that had not been run in years. The carbs proved it. I have them clean and back on. I fired up the engine and it sounds like I have a tinny knock just below the flywheel. I have not ran the engine above idle so I do not know if it will go away at a high RPM. The motor has 150 LBS compression on all 3 cylinders. Does any one have any ideas as to what the noise is? I have a big fear that I have bought a motor with a bad rod. The knock is a higher pitch than what a rod my sound like. Thanks for the help
