Hello,
I bought a new Polar Kraft 160 SE this spring.
It is powered by a 40HP Merc 4 Stroke (EFI). The boat came from the dealer prop'ed with a 10 1/8 D x 15P Black Max. The boat runs fairly well, I just have some issues with the RPM getting up to 6000 RPM and wanting to go higher on smooth water, the problem does not happen on rougher water. I do a lot of river fishing so the water is generally fairly calm.
I started looking into the propeller options to see if I should use a different size to keep the RPM down. That is where the confusion sets in ......
Polar Kraft has a series of "Performance Bulletins" on their site for different boats and engines.
http://www.polarkraftboats.com/images/PLK-OutlanderV160SE-F40LA.pdf
This report is for my boat with a Yamaha rather than Merc engine, but I consider the engines to be indentical in terms of power and weight for the purposes of selecting a propeller.
The specs provided about weight etc are as follows;
Weight : 1750 lbs (boat, fuel and two passengers)
Length : 16' 3"
Hull : V configuration
Engine : 40HP Merc vs 40HP Yamaha
They report shows the boat prop'ed with a 10 5/8D x 12P for the testing with good results.
I ran the numbers in the Mercury Propeller Selector and the same size is recommended. The same tool tells me that the 10 1/8 x 15P is out of expected range for the boat.
A friend of mine had a spare 10 5/8D x 12P Merc prop so I tried it out. Wow, not what I expected.... The boat top speed has dropped to about 18mph from about 28 mph and must be throttled way back or the RPM jumps up and beyone 6000.
So, what gives? I am new to this game and am very confused now.
The engine is mounted one hole up from the bottom, which is different from the report but would it make that much difference? The ventilation plate is level with the bottom of the center keel. In all cases, the propller is not ventilating as far as I can tell.
How can my performance with the same equipment be so much different than the report? Maybe I don't actually have a 40HP, they ran out so they put a 40HP sticker on a 60? Not that lucky eh!
Please any insight is appreciated as I am in the learning process here.
Ultimately I want to know the following;
Is the prop I have now is the best one for my application?
Will going up from 15P to 16 / 17P help keep the RPM away from 6000 when on the river?
Why in the world does my boat behave so much differently than the bulletin or what the mercury prop selector suggests?
Thanks,
Jeremy
Length : 16' 3"
Thanks,
Jeremy
