135 LBS is good. I would replace the exhaust cover gaskets. Item #12 and #14 in the diagram. Water leaks in this area usually show up in the bottom cylinder. Gravity pulls the water down and it enters the bottom cylinder through the exhaust ports.
I checked spark with in line spark tester, I am getting good spark. If I put in a dry plug the cly will fire and run good for a little while. When I pull the plug out it has water beeds on it. I will go ahead and oder the gaskets you recomend. Thanks for your help.
