Overheating
sanibelboater
We have a Merc 150 hp outboard and today our engine started overheating and the alarm sounded. Turned off immediately and kept restarting to get back to boat ramp. Any ideas as to what is wrong?
achris
More fish than mountain goat
Re: Overheating
Restricted water flow to the intakes
Blocked water intakes
Failed water pump impeller
Faulty thermostat/s
Faulty poppet valve
Blockage in the engine cooling passages
Faulty warning switch
Incorrect ignition timing
and the list goes on.
You need to do some proper diagnostics to get closer to the problem.
When was the water pump last serviced? If it's been more than 18 months, I'd start there. Then check the easy stuff, temp sensor, thermostats and poppet...
Chris...........
