PiratePast40
- Mar 21, 2009
- 1,734
Tried my hand at repairing a crack in the jelcoat and it isn't comong out right. It's an 8" crack with jagged edges from trying to dock at a river with strong current. I cleaned out the crack and widened the area to provide sufficient surface. Mixed the jel coat and catalyst and waited for the hour that was recommended on the kit. After I pulled off the plastic, made a first run with a scotchbrite pad and several surface pieces of the repair came off. Waited another hour thinking that it may not have cured completely due to outside temp being around 70 degrees. I then began to feather out the area first with 400 grit wet/dry and then with 1200 grit. I now have some areas with an outline of the crack, a low area, and some discoleration.
My question is: should I just try to cover the surface with another layer of jelcoat or should I try to widen the area again to provide a deeper and better surface for the next layer? It's now basically a surface indentation and no longer a deep scratch.
If I can get hold of some, would styrene be a good idea to help form a stronger chemical bond at this point?
I realize that I'll need to mix a bit hotter batch next time and perhaps wait a little longer for the mix to cure. Thanks for any help.
