Hello everyone
I was reading this forum for several days and decided to post here since I was impressed with all the responses and knowledge present. I am a rookie to boating and boat engines, however I do have some experience with car engines so I am not totally lost (at least I would think so
The problem I?m having is with a 1987 Johnson 110hp VRO outboard. The boat is an 87 Glastron Conroy Z-17.
The engine doesn?t start as expected. Actually it doesn?t start at all unless I play with the manual valve (see picture).
I open the valve all the way to 9 o?clock counterclockwise and close it back to the initial position (maybe I do this 2-3 times) and the engine starts. I can also open the valve to lets say 1 o?clock and the engine would start, then I close the valve. If I run the engine for some time and try to start it, it starts right away, but if I turn the engine off for an hour or so, I have to use the valve again to start the engine.
What I?ve done so far is replaced the battery and replaced the spark plugs.
Any ideas what else I need to check or what would the next steps be?
Thanks,
Mick
Thanks,
Mick
