jasper60103
- Sep 18, 2008
- 2,055
Re: Moving on to the water pump
Did you check the water tube grommet (#10 in pic)? They do wear out or get pinched. If possible, I prefer to replace the entire water pump just to eliminate other variables. I never had a problem pumping water after replacing one, knock on wood.
Here's a test you can do to verify that pump is working.
http://www.youtube.com/watch?v=xAJfBKNs7bo
Good luck.
I just replaced the impeller ....
Good luck.
