i recently got alot of info on this carb i even got an expanded diagram of carb so i can see all parts of carb my problem is my carb does not look like the ones i'm being shown for this motor they look similar but not the same the part i'm concerned about is the high speed jet for this year of carb it's right behind the drain plug of bowl i removed drain plug and there was nothing behind it is there suppose to be something there because the diagram that some one sent me shows a orfic plug but my carb had nothing just drain plug.
Also the drain plug was different than the ones shown everywhere my drain plug looks just like a bolt with flat head screwdriver slot the ones shown everywhere looks just like a bolt also but with a long shaft for a knob of some sort i'm totaly confused on what type of carb i got does anybody know if there is suppose to be something behind the drain plug no matter what type of carb it is or is there a carb that has nothing like mine
the number for carb is 327479(which was stamped on top of carb)
313355 D2 (which is stamped on the bottom of bowl)
the serial number for motor 18402D - E09634 everybody tells me thats a 1964 18hp but carb does not look the same and the ignition coils look different also
my coils look much later than 1964, the gas inlet on my carb enters from the bottom of bowl ones shown to me enter from side???
WOW WHAT DO I HAVE?????
