hello everyone, happy 4th of July. Well, mine is not so happy. I did a ridiculous thing, that I will never live down. I put in the batteries for our 2008 bayliner Discovery 192, in anticipation of taking it out on the 4th of July. I still can't believe I did this, but I actually put negative to positive, and positive to negative, on the main battery, however I wired the backup correctly. I don't know how I did it as I thought I had checked it. I went to make sure I had power on the console and to make sure the motor would turn, and and pop-fiz, smoke and fire. Any way, after cleaning up the mess from the extinguisher the only obvious damage is the ruined battery, and a melted negative terminal wire. This was on the backup side, the side that was wired correctly. I am SURE there is additional damage, such as the starter motor, relays, alternator, etc. I'm just not sure what the potential damage could be. Their is a perko switch and an automatic charging switch. Typically, what would be ruined by this carelessness? I am able to get everything to work now, except for the console gauges, which are dead, and the motor will not turn. Stern driver still moves up and down, horn works, bilge pump, fan, etc. no gauges though, no cranking. What do you think I ruined? Thanks all for any help. Happy 4th.
