1988 johnson 150
Brewha5
How do separate the upper section of the driveshaft from the lower section.
Dhadley
Re: 1988 johnson 150
If your driveshaft is origainal it's a one piece shaft. If it's been replaced with a newer 2 piece shaft there is a special tool used to pop the top half out of the lower.
Brewha5
that explains it then, how come i can find a two piece online for roughly 350.00 but the dealer i called wanted 680.00 for a new one?
Dhadley
We'll assume you need to replace the driveshaft in your motor. Make sure the one you found on line is the correct one and the price includes both the upper and lower. If I remember right each end is about 300.
