Re: 1977 johnson 25ho lower unit leak???
water is not good, and yes the above opost is correct it does turn to a cream colour. I have jsut dropped my lower leg 4 times with water in the lower unit. there is the preller seals, or the little o rings in the screws in the bearing carrier on the propeller shaft, or the shifter seal and gasket, and the driveshaft seals under the water pump. You will buy everying in one kit and do it all at once. dont be like m,e and only fix one problem....do it all at once. it is not a hard job and once it is done just take your time and understand what it does....mines a 78 so i feel your pain on the older stuff it sucks.that kits cost me 68 dollars at the local boat shop here in the priaries. but online its cheaper.your call
Water is bad in any oil its not good....and will wear out your components...much faster, then rust issues occur its just not good.
