tiku
- Jul 23, 2007
- 31
Hello all!
Been asking questions on the engine side of this forum but finally decided to start a new thread about the troubles and fun times I have had and shall have in the future.
This is what the boat is supposed to look like after it's reassembled (Or, it this is what it looked like when I started)
Funny thing the boat is based on Slickraft desing and they were orginally manufactured in Finland under lisence from Slickraft until they decided to change the design so no fees had to payed.
So far I have managed to blow the headgasket and decided to tear the original (1975 181cid) Mercruiser apart. Well, it's pretty much gone (literally rusted away so I'm thinking of either squeezing in a v8 or to be more realistic, a v6 version...
This is the old engine being carried away..
Then, in order to get some room and better access the hardtop had to come off. It was easily achieved by using some innovative measures.
I have literally read nearly all the stringer repair threads on this forum and I had secretly hoped that mine would be fine. Especially so because there were really no soft spots around. Well, cant be sure unless you see it for youself... Removed the red vinyl flooring and found out that the floor is glassed..
Yes! no worries then... Right! Upon closer examination this is what I found:
Yup, It's water down there... The boat has been sitting off the water and covered for two years now and there is system of drain pipes that were suppodes to take care of the water but no..
The stringers (plywood) are glassed only up until about 75% of their height, the top and sides are left uncovered and the floor is moist pretty much everywhere.. Damn..
I'm not sure but it sure seems strange to have this white "thing" covering the underside of the plywood.. Glass is on the other side..
I decided to dig a little further backwards and it seems the same there..
The work continues.. Back to the site in few days. It seems that I can also contribute to this forum by posting yet another stringer/transom general overhaul thread..
