Re: engine overheated with muffs on
yes i had a little bit of water coming out of there because it was hot this thing has been sitting for awhile maybe the thermastat is bad well it locked up did i hurt anything
it locked up??.. you definitely overheated then..did you damage anything?.. maybe maybe not...wont know till she cools down. After overheating, some here will tell you to buy new head gaskets and change them out...
is it a two stroke?..did you have the right oil/gas mix??
let her sit and cool... take a look at the thermmosats and see what they look like. you can as a quick test, take the stats out and put the covers back on.
then with muuffs on start her up and see if the water comes out of the hole stronger... if it does then bad stats...if not then back to restriction or bad impellar... you should see this pretty quickly..so if you get no better water then shut her down to prevent another overheat.
