ok so specs are in the thread name as well as the problem. I have a stern drive OMC cobra 3.0, shes over heating intermittently, took her on the water didnt over heat, tried flushing her system after i took it out, she overheated. I took off the inlet hows coming from the stern drive while running the engine and there was no water coming up the hose ( yes i had the muffs on and water running). i can blow water out the hose and suck it up but the water does not get pushed up. i can flush water freely through thermostat housing and and engine but she still over heats.
my question is what could be wrong? impeller, thermostat, water pump. Is there something that I am missing? could an inline water pump work if i eliminate the impeller so to speak.
