My Mercury 650 motor was running good then started having trouble at idle. When I pull back neutral throttle, she dies. Finally got her into gear and running fast then the power cut by approximately 50%. Slowly feels like she wants to go faster but never regained full power back. Drove it once since then and had to adjust idle screw all the way in to keep her idleing without stalling. Still feel skipping at WOT and not full power. Replaced the fuel line and no difference. compression seems to be around 150 psi at each cylinder. Used spark checker and shes firing off good at the house. Did notice that while checking spark and compression on the lowest cylinder on the motor that she didn't wanna run at all. Plugs look a little oily to me but not sure what's normal there. Please help
*also notice small amount of fuel puddling inside motor housing directly below carb.
