Hello. I have a 1973 evinrude115 v4. It runs great when I first take off but it picks up a terrible miss after it warms up and only at full throttle anyone have any suggestions. Thank you
That could be from several causes including a fuel pump unable to keep up with the demand or ignition coils breaking down when heated.
If you are using fuel supply components of less than 5/16 ID, you may want to upgrade.
If the ignition coils are cracked, discolored, swollen or if the potting material is distorted, it would be a good time to replace them before they destroy your powerpack.
Check your fuel supply carefully for air leaks as well.
I have the same motor and ran it on muffs a couple of weeks ago and burned up the water pump. Not the muffs fault - I forgot to turn on the water So I replaced the water pump 2 days ago and got it running again, on muffs, and the overheat buzzer went off. This time no damage, but I quickly found out that the muffs don't seem to seal well enough to force the water into the water pump cavity. While I had the L/U off I hooked up the muffs and held the cups on both sides with my hands and the water was forced up into the water pump cavity. I put 'er all back together and started it and held the muffs and the water started to pump. Just below the rear of the cowling there are a couple of holes that have a little spray of water (like a mist) when it's working correctly.
