starter problem
aspeters
if you bypass solenoid and put power to starter and nothing happens deos that mean starter has gone bad?
Daviet
Re: starter problem
Make sure the ground cable is clean and tight.
Yes if you apply 12 volts to the starter by bypassing the solenoid the starter should spin.
aspeters
Re: starter problem
and if that is done and it still doesn't spin is starter bad?
