Hi Everyone.
I'm new to the forum, though I've been taking advantage of the wealth of knowledge on here for some length of time.
Here is my situation. Please please, can somebody know what is wrong with my motor. I'm not ready to pay $109.00 an hour for marina labor. :-/ (broke college student).
So a little over a month ago, I bought an old crappy boat with a 115hp johnson on it. I just wanted to take the motor off to put on my 20ft center console.
On my boat, I used to have an 85 johnson 75hp. It was way underpowered, which is why I got this 115. The wiring was all the same, so it seemed plug and play. Tilt / trim works great. Starter works just fine. Nothing seems amiss in terms of hooking it up to the controls.
Now the nitty gritty:
When I first got the motor, it wouldn't do anything. Turned out the starter was bad. Got a new one. Then it would turn over, but not run, so I opened the airbox to find a huge wasp mud nest. Cleaned that out, and tried again.... The motor ran for a few seconds at a time, but very roughly, and would splutter and die. I ordered carb rebuild kits, and put them in. Adjusted the floats perfectly. Then, figured out the VRO pump wasn't working (The oil side had been disconnected and I was running 50:1 as most advise with older VRO pumps). Didn't take long to see it wasn't pumping fuel. The diaphragm looked old and was very rough. After realizing a new VRO pump is 340 bucks, I read on this forum I could replace it with a similar fuel only diaphragm pump (part number 0383765), which I ordered and mounted.
So far, new starter, new carbs, new fuel pump. New plugs and leads. All new fuel / vac hoses and lines. The reed valves look good. Good compression - 115ish in all 4 cylinders.
The timing doesn't seem too far out, and no matter how I adjust it, this thing just WILL NOT IDLE.
The motor runs for a few seconds.. maybe 30 at the most, and then all of a sudden, BOOM. Stops. It doesn't splutter as though it's running out of fuel. It dies as if someone has just turned off the key. Sudden and instant.
Should I rule out fuel delivery as a potential problem? the fuel filter is ALWAYS full of fuel. The pump I installed is brand new and pumping well.
Do I start looking for electrical problems?
Please help. I really want to get this thing out on the water. :-/
Thanks in advance everyone.
Brett
Brett
