brockly_9000
- Jun 8, 2010
- 5
I have been now battling this problem for 2 months. At first it will run fine, for bout 15 min. Its a small lake so I'm on and of the throttle. After bout that amount of time, Ill back off the throttle down to almost an idle to turn around. I give it gas again and it bogs. It will run WOT but barley makes plane. The longer i keep it WOT it slowly picks back up. So Ive done tons of tests from the repair manual. And everything checks out. Ive replaced the power pack last fall, cause it did lose a cylinder. Now I have spark all across the board even when its dogging. Ive been through the carb. Rebuilt completely 2 years ago, and i cleaned them a couple weeks ago. Also fresh gas, all new gas lines from the tank to all the carbs (no leaks). Rebuilt the fuel pump last week. Tested the timer base yesterday via how the book said. All came out fine. This is my first boat, and cant afford to take it anywhere at shop prices now days. Any help would be greatly appreciated.
