1989 4.3 omc 2 barrel rochester
This is a pic of where the acc pump goes down into the carb, just wanting to make sure this is correct when i pulled it out it looked like this?The manual says pull that spring out and tip it upside down and a ball should come out, well i did, and saw the little snap ring in there and took it out the ball is stuck in there is that ok? i see the new kit has 3 balls but all i can tell is there is one and the hole just above it (strainer?) i believe around it has nothing in it at all or anything ever in it. just want to make sure this is all correct because the boat was having major hesitation issues on acceleration so i was told acc pump! thanks.
http://i110.photobucket.com/albums/n106/brian102/Mobile Uploads/1278719586.jpg
sorry for lack of proper wording first time taking a carb like this apart!
