wannablast
- Jul 9, 2010
- 6
I have a 7.4 liter with a bravo 1 that is NOT pulling water to the raw water pump. I always remove the impeller when I winterize and put it back in or a new one if the old one isn't in good shape the following spring. This year it ran for about 15 minutes and then it quit "spitting" water out of the thru hull exhaust for a minute or so and then started spitting again. It then quit spitting and the temp climbed to 200 deg and I shut it down. I pulled the impeller and it was trashed. ( I found all the broken pieces from the impeller.) I replaced it with a new one and it ran fine for about 30 minutes in the driveway with the muffs on. I shut it off and took the boat to the lake the following weekend. I unloaded and as I idled out I looked at the temp gauge and it was climbing above the normal 140-160 deg all the way up to 200 deg and I shut it off and dropped anchor. I took the boat back home and when I pulled the impeller all the vanes had split but didn't separate so they are all accounted for. I removed the engine water pump and pulled the back plate and the vanes look fine on it too. I looked at another bravo drive to make sure I didn't hook the raw water supply hose up wrong and I didn't. I ran water through the raw water supply hose and it pours out of the lower unit. I've done this for about 12 springs with no problems. What next?
Thanks
JT
Thanks
JT
