l008com
- Jun 14, 2007
- 766
Ok, that's not "exactly" what my oil alert sounds like. More like a very loud continuous high pitched beep coming out of my throttle. When I was a kid, I remember that the beep would come on whenever the oil tank was down to 25% (about 1 quart left).
A few years ago, it came on and wouldn't go off. I brought the boat to a marina and they replaced the whole oil tank. Then it was fine. It was a bit expensive though.
Well it's happened again. During a boat ride, the alarm chirped a few times. Then came on for a few seconds, then finally, came on and stayed on. Funny thing is, I had a half a tank of oil. A mechanic I know also said that it beeps like that for overheating. But I don't think thats it, there's a nice solid pee stream coming out of the motor, and i only idle around. Plus the beep come on as soon as you turn the key, even with the motor not running.
So I bought a gallon of oil and filled the tank, but sadly, that hasn't changed anything. Then I disconnected the battery for a few minutes, to see if that would 'reset' the sensor. But that also had no effect.
So as it is right now, the beep starts as soon as you turn the key slightly. Motor doesn't even need to be running. The oil tanks is totally filled (possibly slightly overfilled, oops).
So what would be causing this mind-numing beeping to continue? I really hope I don't have to replace the oil tank again. It's only a few years old! The first one lasted 18 years or something. Plus it was expensive.
Oh and the motor is a 1989 Mercury 90HP, 3 cylinder, not-fuel-injected model. But it is oil injected, I don't have to premix.
