Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
If it'll only run with the choke engaged...the carb must be cleaned. The slow speed circuit is dirty...clean it up.. I'm sure it'll run with a carb kit properly installed.
New here but just to let you know the last boat i helped out my buddy on kept doing the same thing. Every time we would clean the carb after a short time it would start this problem. Finally found the manual pump in the fuel line was coming apart on the inside and the screen in the fuel pump on the motor was busted letting these little pieces into the carb. Probably no help to you but just one thing I have seen.
