Hi,
I've got a 2009 Crestliner 1700 SpotFish with a 115hp Mercury engine, and I currently get around 45mph top speed on a good day (GPS), at about 5200 RPM. On the side of the motor, I saw that WOT is 6400 RPM. The boat struggles to get on a plane when it's loaded down, but eventually gets there and usually has sufficient power afterwords. I was just wondering if there was a prop that could achieve a higher top speed (say 50MPH) without losing any low end power. I'm at around 1400 feet elevation. All I know is that I currently have a black three blade prop with a sticker that says 14 on it. When I bought the boat the guy told me that with this specific prop, for maximum performance you should trim the motor so the top of it is out of the water and so it make a really annoying sound.
EDIT: Everything is stock on the boat, and the speeds were with just me, 140lbs and nothing else in the boat.
I remember last year, late fall a few days before the lake froze over. I gave the boat about 7/8th throttle and it screamed up to around 6000 RPM and I backed off right away thinking I was going to blow the motor. If I recall the GPS read a little over 54MPH.
