texlmc
- Jul 10, 2010
- 3
Ok first be gentle I?m new to working on boats.
I have 82 Bayliner Capri with AQ125A and 270 outdrive. WAS going to take kids to lake tomorrow but wanted to check everything out first. Put on the earmuffs and started the boat and no water out the exhaust. So removed cap on heat exchanger and no water from the impeller side of the motor.
OK the troubleshooting began. First checked the impeller and looks like new to my surprise. So problem has to be from impeller to water intake. Took off hose and put water straight to the impeller tube. That worked so I thought I must have clog in drive or at water inlet. However after running water thru tube backwards there is no obstruction.
Put all back together and thought I would try again. After 7 hours of looking and scratching head I decided to rev the engine just to see the outcome and BINGO we have water to the heat exchanger.
Shouldn't I have water running through the system even at an idle?
Can't find any reason that there would be low suction. Just don' want to damage anything.
