Eric 3.7LX Alpha 1
- Mar 27, 2010
- 3,027
Re: 3.7 merc cruiser wont start
Be careful with the motor mount bolts, depending on which ones are loose you may throw off the alignment of the gimbal bearing and the outdrive. The motor mounts are adusted using an alignment bar thru the gimbal bearing into the coupler on the back of the engine.
Can you take a picture of them and post them up here so we can see which ones are loose?
i also noticed my bolts for my motor mounts were loose. can i just tieten them up or how do u know were its suppose to be. i could move it 3/4 of an inch or so.
