Where can i attach fuel pump after i remove the VRO on 86 evinrude 50 hp?
catlew
I got some good answers to a previous question. Now where can i attach the fuel pump after i remove the VRO pump?Any help is greatly appreciated!!!!
ezeke
Re: Where can i attach fuel pump after i remove the VRO on 86 evinrude 50 hp?
You should find that the pump bolts directly to the engine with two screws. The threaded holes for the screws are are on either side of the hole for the pulse.
tashasdaddy
this is the fuel pump you need. http://www.iboats.com/Fuel-Pump/dm/*******.018270172--**********.482058016--view_id.174141
