i have a 1999 mercury force 120hp. i had emailed before about how i had trouble starting and that my starter would lock against the flywheel as if it didn't have enough juice to turn the motor over. you of course told me to check my battery connections and the solenoid as well.
turned out i did burn up my starter. i bought a new one and put it on. first time i took it out it worked great. no issues.
the second time i took it out i went to start it and only got a buzzing noise coming from the starter. after about 5 minutes of waiting i tried it again and it started up. very odd, but figured it was nothing.
i then went out again the following weekend and it did it again.
now the third time when i took it out today went to start it, when i did the starter kicked into action and went to turn the motor. didn't do it on the first try which i know is not unusal when a motor is cold. so i went to try it again and this time got the same buzzing noise. so i waited like the last two times, only this time it never kicked back over. i keep getting the buzz noise as if it is trying to get the starter to work and it won't turn.
of course i had to pull out the boat and when i tried to put the motor up odd thing happened. i couldn't get the button to raise my motor. so i thought maybe i killed the battery or something. i drove home, and when i got him tried the motor again no response just buzzing. but for some odd reason at that point i was able to raise and lower the motor.
i put on a new starter solenoid and still nothing is working right. even the raising of the engine and lowering is taking some playing with the switch.
Any ideas what the heck is going on here? Please help
