adding tilt/trim to 25HP tiller handle
FH alumni
I have a 2008 25HP 2 stroke tiller handle short shaft. How hard is it to add the trim/tilt feature? Can this be done? Boat is manual start but I have a 12v battery in the boat to run my depth finder, gps etc. so power is not an issue.
Approx how much weight would this add to the motor?
Can the motor still be moved off and on the boat? (of course with assistance as even the 2 strokes are heavy)
Not really worried about raising the motor out of the water, just looking for a way to make small adjustments to trim underway for optimum performance.
James R
Re: adding tilt/trim to 25HP tiller handle
It helps just a little if you tell us what motor you have.
