what's your favorite bass bait
JAY 22
personally i like to use poppers. i haven't had to much luck with spinner baits or buzbaits, but then again i grew up trout fishing so i never had to much experience with bass until about 6 months ago. if you know any good techniques let me know i'll take all the advice i can get.
scipper77
Re: what's your favorite bass bait
Where are you fishing?? What is the structure like?? My favorite lure on small ponds from shore is not the same as in a river or large lake.
The most generic answer I can give is to try Senko's on a texas rig.
If you are just learning to target bass then you will soon learn that many lures are great lures but if you use them in the wrong conditions you may abandon them in the circumstances where they might work.
rjn cajun
Up here in the pacific northwest the water is alot colder and we don`t have the bait fish that the other parts of the country have. On any given day I will start by throwing a crankbait to locate and find the depth the fish are at. From there I will try several different patterns. So to answer your question it`s a crankbait first then whatever the fish like.
JAY 22
scipper, i usually fish a small creek/river near where i live it's actually the spillway for a dam. most of the time the water way is pretty small however recently they have opened up the dam or something and the water seems to be much higher. the only structure is some fallen trees. there seems to be mostly bass but alot of carp as well. not to many bait fish that ive seen. poppers were doing well for the last couple months but now their not hitting so much. also it's much warmer now so i think most likely it's the change of water temp. that has changed their feeding habits
gonefishie
Texas rig a tube in the color of the crawdads in that creek. If you don't know the color then stick with greenpumkin, it's the universal color. I reccommend Hooked-Up Bait Co. tubes but most tubes will do. The 4" turbo tail tube in the color they called natural craw is dynamite in river and creek. Use as light of a weight as you can get away with. 1/8oz is a good start, too heavy it will hang up in the rocks more. Always cast upstream and let the current carries the lure down. I'm assuming you already know they like to hang out behind current breaks and eddy. Since you're just starting out, get the In-Fisherman series of videos. They have species specific videos that will give you lot of info.
potatoe
senkos on wacky rig seem to do great job anywhere. try green, pumpkin seed
SteveRoss
EDIT: Bad, bad, bad idea, Steve
JB
Senkos catch more fish, surface fished original Rapalas and poppers have a lot more fun.
HopeSheFloats
My favorite? would have to agree with JB, any top-water lure...nothing more exciting than that expected yet unexpected explosion out of the water :D
For searching, I would second the crankbait choice.
ahoy49
Plastic worms and a bullet weight. Top water is more exciting thoiugh.
Ahoy
bassman284
The buzz bait is far and away my favorite. Downside is I keep using it when conditions aren't suitable, just for the buzz.
I've had good results with Senkos and Senko knockoffs, but they are usually ungodly boring to use.
FuriousMob
Gary Yamamoto's lug worms...black with silver specs. Works so far in all the lakes and ponds I've tried around here in central VA.
Thad
I used to have two boxes full of everything I could possibly need. Try and trry until you find what they are hitting that day only to wait for them to change their mind. One day, I figured I would try for some big Blue Gills so out went the leach. Bam! Several Bass later, back to the marina for more leaches. My new Bass bait:D.
Now I only have a couple Rapalas for Northern and if I can't get any leaches, I don't go Bass fishing.
kenmyfam
Off white rubber wiggly worm with a flappy tail.
Works at Rice lake Ontario.:)
Hey Jay,
I live in Vero Beach, Florida and I love bass fishing. You said you're fishing at a dam fed creek that has some laydowns. I would take into account a couple of things. First, I would change baits based on the speed that the creek is flowing. I saw someone post to try senkos. I have to agree that a senko is a great lure for a couple of reasons. I used to be a fishing guide here and I found out about the senko soon after the original one was developed. I fell in love with them and even had a rep come out from the company, Gary Yamamoto Custom Baits, and we caught over 100 bass that day fishing them different ways. You can fish them on top by using them weightless on a texas rig. This works well in slower moving water when the topwater bite is on. When it seems to slow down or stop, add a light bullet weight to it to allow it to sink slowly. This will allow you to work the water column more efficiently. If the creek is shallow, the senko will sink slowly unweighted naturally. The senko is a great bait to work around structure because when you rig them texas rigged style they are virtually weedless. This means you can work them over the stumps, logs and any other obstructions. The faster the water is moving, the heavier the bullet weight I may use. Although no longer guiding, and thus no longer sponsored by Gary Yamamoto Custom Baits, I still buy that brand and here's why. First, I like to give my business to the person that came up with the original design or idea. I'm loyal that way. Second, the plastic they use allows the bait to "shimmy and wag" more than most other spin offs. Third, They just don't add salt to the bag of baits, they impregnate the soft plasic. This does a couple of things. It adds weight to the bait allowing me to cast it a very long way on a baitcaster, and if you're fishing around cover, I would recommend using one as they offer more power to horse fish out of heavy cover. The impregnated salt also stays with the bait, and as the bass bites down on the senko , he gets the salt taste, and as this is a natural occurance in live prey, the bass will tend to hold on longer to it allowing you more time to sense the strike in moving water, thereby allowing you more time to set the hook.
Gary Yamamoto custom Baits(GYCB), makes the senko in various sizes and thicknesses, and they come in a ton of different colors. The most popular size by far is the 5". Find out what colors are the "go-to" ones in the area you fish and try some of those. Don't be afraid to order new or varying colors as you may find a magic one that nobody else knows about. I did. Also a lot of times I change colors to experiment, and I feel the fish are targeting the magical action of this bait more than any particular color. You can downsize if necessary, if you're creek has smaller fish. The smaller bait will get more bites from smaller fish but make no mistake, larger fish will also hit these smaller senko's, making it a win win situation. Although I love to target big fish, and have caught many here in Florida, sometimes when I take my son with me it's about the number of fish caught, not just the size. If you have any other questions, you can reach me at my email: terry.fagan@att.net
