bob johnson
- Feb 25, 2009
- 4,306
many people say that the actual number isnt as important as if they are with in 10% of each other, and thus the motor is runnign smoothly...but
you hear numbers like 90 psi
and then the next guy has 120 psi across the board , and still another guy has 150 psi across the board...
i have always thought, heck same motor same year same modle the motor with the higher compression motor should seemingly have more HP!!
well i went and bought a used set of heads for my 1995 60 degree looper 115 hp, because i wanted to try and look over the possible causes of one of my heads running hotter than the other..
they came in nice, and cleaned them up and removed the seal inserts for the T-stats...then i went and took a head off my spare moroe which is also a 60 degree looper but it is a 90 HP isntead of the 115, but the parts all interchange. I t has been said that the difference was all in the carbs...well after i cleaned up the 90 hp head, i measured them ..
sure enough the combustion chamber is about .080" deeper on the 90 hp than the 115 HP.
since the bore and stroke are identical... the compression MUST be higher in the 115HP!! RIGHT???
this all leads me to think that compression is VERY important not only in comparison to the other cylinders, but also to the amount!!!
the higher compression a motor is , the more it probably will produce the HP sticker on the COVER!!!!
Funny on the site i look up parts, they say the 90 hp head will fit the 115 and 90 hp models..
sure they FIT, but they are not the same!!!!
bob
bob
