I am replacing a 1973 65hp Johnson with a 1977 70hp Evinrude on my 16 ft Starcraft. I wanted to use the existing transom bracket steering setup presently on my Starcraft. I tried to undo the nut on the 'stem' on the Pitman arm on the Johnson thinking it is part of the screw but it did not move. I am hesitant to use a great amount of torque until I make sure this is supposed to unscrew and that it has a normal (counterclockwise to loosen) thread. Also I believe this 'stem' has a ball joint where it attaches to the steering cable. How does one remove this ball from the cable end? If I could do that I could use the 'stem' that is already attached to the 77 Evinrude. What is the spring for on the bronze looking cylinder on the end of the steering cable? Does that bronze piece unscrew from the cable end? I have two manuals and neither discusses the steering setup.
