jwellcraft
- Nov 5, 2009
- 233
Hi does anyone know if a 1994 crankcase cover can fit and work on a 1992/1993 crankcase. Reason I am asking is that I recently had a 1994 Johnson 150 60 degree V6 but it developed that leak in the number one cylinder so I purchased a used block that was machined and said to not leak however the vendor thought is was a 1995 or newer block but it turns out that it is a earlier year than 1994 because the crankcase cover on the block doesn't have the upper bearing vent in it that tee's into the air box. I went online and looked to see what years the upper bearing vent started and it was in 1994 so I am wondering if my 1994 crankcase cover with the vent can work on this 1992/1993 crankcase. I think they made improvments as year came so wouldn't want to go backwards.
