The above motor was not starting immediately but eventually started after turning the key many times. We examined the motor with the cover off and found the starter solenoid was not traveling far enough up the shaft to engage the flywheel. We also noticed the starter body was getting hot but were told this is normal because of high amps going through it. We sprayed the solenoid shaft with WD40 and the problem actually got worse, possibly because grease slid down the shaft.
At any rate, does anyone have comments on replacing the solenoid, including a diagram of how to do it, and where are the best places to buy starter solenoids for this motor?
